-   -   pertronix coil (http://forums.pelicanparts.com/porsche-911-technical-forum/755872-pertronix-coil.html)
ralph808 06-13-2013 10:31 PM
pertronix coil
I have an 85 Carrera. can I use the 0.6 ohm Pertronix coil as a direct replacement for the stock coil? thanks.
SchnellSchweitz 06-13-2013 10:48 PM
Do you need to use Pertronix?
MSD has a great coil for our engines. The MSD High Vibration Blaster Coil - 8222 - is one of the most common replacements. Of course, most folks are also equipped with a MSD 6A or 6AL. You may already have a Pertronix ignition box???
ralph808 06-13-2013 11:51 PM
thanks. I will look into the MSD.
wwest 06-14-2013 07:43 AM
With a CDI it's best to use an "E & I" laminated iron core transformer type "coil" rather than the simple "I" core coil.
Excellent tutorial, even OUTSTANDING..
Quick read, page 45-46 and 58.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&ved =0CCwQFjAA&url=http%3A%2F%2Fwww.worldphaco.net%2Fu ploads%2FCAPACITIVE_DISCHARGE_IGNITION_vs_MAGNETIC _DISCHARGE_IGNITION..pdf&ei=mDK7Ud_NK8f6qwGj8oDAAg &usg=AFQjCNFwi_UAT21C-XTGAVaRHuqNm8xVqg
wwest 06-14-2013 09:02 AM
~$60.00
http://forums.pelicanparts.com/uploa...1371225730.jpg
