pertronix coil
I have an 85 Carrera. can I use the 0.6 ohm Pertronix coil as a direct replacement for the stock coil? thanks.
Old 06-13-2013, 10:31 PM
SchnellSchweitz's Avatar
Do you need to use Pertronix?
MSD has a great coil for our engines. The MSD High Vibration Blaster Coil - 8222 - is one of the most common replacements. Of course, most folks are also equipped with a MSD 6A or 6AL. You may already have a Pertronix ignition box???
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 06-13-2013, 10:48 PM
thanks. I will look into the MSD.
Old 06-13-2013, 11:51 PM
wwest's Avatar
With a CDI it's best to use an "E & I" laminated iron core transformer type "coil" rather than the simple "I" core coil.
Excellent tutorial, even OUTSTANDING..
Quick read, page 45-46 and 58.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&ved=0CCwQFjAA&url=http%3A%2F%2Fwww.worldphaco.net%2Fuploads%2FCA PACITIVE_DISCHARGE_IGNITION_vs_MAGNETIC_DISCHARGE_ IGNITION..pdf&ei=mDK7Ud_NK8f6qwGj8oDAAg&usg=AFQjCNFwi_UAT21C-XTGAVaRHuqNm8xVqg
Old 06-14-2013, 07:43 AM
wwest's Avatar
~$60.00
Old 06-14-2013, 09:02 AM
