-   -   a/c vacuum pump recommendation (http://forums.pelicanparts.com/porsche-911-technical-forum/756084-c-vacuum-pump-recommendation.html)
Ronnie's.930 06-14-2013 06:02 PM
I'm going to buy an a/c vacuum pump to use on my 930 as well as on my other personal vehicles. I was wondering what CFM rating is considered "good". I did a search but couldn't find anything . . .
Gordo2 06-14-2013 06:42 PM
Harbor Freight Vacuum
Ronnie,
COLB might chime in - he bought the Harbor Freight vacuum unit for the R134 conversion we did on his car recently.
http://forums.pelicanparts.com/porsche-911-technical-forum/755318-first-project-thread-88-cab-c-retrofit-cheap.html
The little pump seemed to do a sufficient job evac'ing the system. We ran it for about 15min initially to see if the system had any gross leaks, then a full hour for complete evac prior to charging with R134.
Considering the (hopefully) limited frequency that a non-pro would be using a vacuum, it's hard to beat the price.
Spec's may be on HF website.
Gordo
Mr Project 06-14-2013 07:02 PM
I have a small 1.5CFM pump. I believe it's this one:
https://www.ackits.com/pc/90060/Vacuumpump/90060+-+Mastercool+1.5+CFM+Dual+Stage+Vacuum+Pump
I've used it on probably 10 cars, it works OK, with time and repetition it will pull down about 21 inches of vacuum - no more. In hot weather (85+ degrees) I have to run a box fan or something on it while it is running or it will overheat after 5-10 minutes and shut down. In cooler weather (50-60 degrees) it does great. But who works on A/C when it's cool out?! :)
Anyway, good enough for occasional use and I believe it is higher quality/more effective than the air-compressor driven units. But not pro quality.
SilberUrS6 06-14-2013 07:11 PM
You don't need a vacuum pump. Just use two SPAL fans and trinary switch. Your AC will be fine.
Mr Project 06-14-2013 07:48 PM
BTW, the one I linked, I think you can find for about $100 now. I think I paid just a bit more than that a few years ago, not sure why the high price on ACKits.com.
Ronnie's.930 06-14-2013 07:52 PM
Ha! Now it is time for YOU to get the ceeeegarrrrr!
Thanks for the suggestions.
wwest 06-14-2013 07:57 PM
Originally Posted by Gordo2 (Post 7499227)
Ronnie,
Gordo
HF is currently handing out 25% discount coupons for use ONLY on the 4th.
http://www.harborfreight.com/25-cfm-vacuum-pump-98076.html
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=2&ved =0CDEQFjAB&url=http%3A%2F%2Fwww.harborfreight.com% 2Fmanuals%2F98000-98999%2F98076.pdf&ei=_um7Uf_MMcWtqwGHq4GADg&usg=AF QjCNH2MGr0IZh7ojTtsZVnqA8YQltdJg
crownarch 06-14-2013 08:00 PM
You can buy a 2.5 cfm unit from Harbor freight Tools for a little over 100 bucks.
Synchro Joe 06-15-2013 08:31 AM
Vacuum
SmileWavy:D Now that is funny chit!
shadowjack1 06-15-2013 09:24 AM
Your local FLAPS may let you use one for free. You put down a deposit, use it and then return it for a full refund.
rusnak 06-15-2013 10:30 AM
I have the 6 cfm Robinaire pump, but you can get a smaller 4 cfm unit as well.
Be sure to change the pump oil each time (Grainger carries it). I would not buy HF on this item.
69-912-swt 06-15-2013 12:06 PM
+1 SmileWavy
