-   -   Where do get bulk fasteners? (http://forums.pelicanparts.com/porsche-911-technical-forum/756309-where-do-get-bulk-fasteners.html)
rennch 06-16-2013 12:36 PM
Hi,
Instead of constantly running to the hardware store every time I need a nut or bolt, is there a place online to get a whole array of regular and/or stainless fasteners?
rwest 06-16-2013 12:48 PM
McMaster Carr is excellent; also Fastenal sells bulk.
sjf911 06-16-2013 12:55 PM
1+ on McMaster-Carr. I also use BelMetric.com.
dntlft 06-16-2013 12:58 PM
The Pelican site sells hardware sets. Just search under 'hardware', they have nuts, bolts, washers ect.
Neilk 06-16-2013 12:59 PM
So then the next question is which fasteners to get... 10 and 13 mm nuts, but how which bolts and what length? I guess you could check out the parts book to get an idea.
SilberUrS6 06-16-2013 01:32 PM
^^^this.
timmy2 06-16-2013 02:20 PM
Grainger as well for things like aluminum crush washers, nuts, bolts etc.
Ayles 06-16-2013 03:12 PM
Is there a recommended assortment for our cars from one of these suppliers?
kerthunk 06-16-2013 03:18 PM
McMaster-Carr is great if you don't need your fasteners in yellow zinc. If you want the yellow/gold stuff, then Belmetric is the place to go. I usually keep a decent supply of m6 and m8 nuts+washers as these will cover the majority of your needs on an older Porsche.
The bolts are a little trickier to order as the factory tended to spec out lengths exactly as needed and not just in more generic "close enough" sizes.
m110 06-16-2013 05:46 PM
Telephone the host and ask, they might have some frequently used kits.
I have this (which I don't believe the host sells)
http://www.a u t o m o t i o n.com/wurth-metric-hardware-kit-general-bolt-nut-assortment-490pieces-for-porsche.html
rwest 06-16-2013 07:13 PM
I didn't even think about our host, but they have a bunch of kits: PelicanParts.com - Garage Gadgets > Wurth Assortment Kits
bodmin 06-16-2013 09:13 PM
I've had the same problem getting yellow zinc passivated (YZP) nuts & bolts. I managed to find a UK supplier, but unfortunately they only sell large quantities (200/500/1000). This is fine for nuts & washers where only a few sizes are required. However bolts are a different matter with such a huge array of sizes. That being said I did buy 500 M6 x 12 and 500 M6 x 16which Eagle Day describe as Porsches favourite fasteners.
www.shopfasteners.co.uk
The other option I am l looking at is to buy bright zinc passivated (BZP) bolts which are readily available in small quantities and dip them in Yellow Zinc Passivating solution (Zinc Chromate?). This is easily obtained and only requires clean BZP items to be dipped - no electrodes or electroplating involved. The variables are concentration, temperature, and time -according to my research. I haven't tried it yet - are there any Pelicanites who have tried this?
Final option is simply bit the bullet and buy from Porsche dealer - not that expensive for small quantities.
bodmin 06-16-2013 09:14 PM
Sorry that link should be
Welcome to shop4fasteners
shop4fasteners.co.uk Hexagon High Tensile Setscrews - Zinc & Yellow YZP
Peterfrans 06-16-2013 09:31 PM
I buy mine at wegertseder.com They have a huge selection of nuts and bolts. Unfortunately only a german-language site.
Pazuzu 06-17-2013 08:52 AM
Metric Fasteners
944 General Purpose Fastener Kit
Eagleday always has an interesting collection of yellow zinc stuff
schumicat 06-17-2013 08:57 AM
any auto parts store will sell a hardware assortment that has most of the common sizes. the one I get is available for SAE, DIN metric (euro cars) or JIS metric (asian cars). grilot's garage also sell such assortments as does pegasus racing. i bought the pep boys one and an empty grilot's metal storage case to keep them in.
