will this sway bar fit my 911?
I am missing the rear sway bar on my 1971 911. From what I understand the one that came on my car is a 15mm. I have found a 18mm sway bar from a 1976 911. Will this fit my earlier model 911?
Thanx. L |
Later control arms use a threaded boss for a bolt-attachment to the later drop link. It would be cleaner to find a pre-owned early sway bar setup or to install an aftermarket SB (uses different suspension attachment location). BTW, PAG also offered a 16mm version. Go here for more early 911 info: Early 911S Registry or purchase a copy of Bruce Anderson's 911 Performance Handbook. Sherwood |
