steeler1
Restoring Fuchs wheels
Where in Northern California Bay Area can I get my Fuchs restored anybody know of a place. Thanks
Search is your best friend.
Weidmann Wheels best in the country and close to you. Long wait.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Recreational User
This was a serious question?
Rescuer of old cars
Where you have them done also depends on your definition of "restored" when talkin about Fuchs. If you are thinking of a bright, polished finish (which is not original), there are many places to consider. If you want them re-anodized as original (truly restored), there are only a handful of places in the country that can do this. Harvey is one, widely regarded as the best. Others include Al Reed, and Wheel Enhancement in CA, with a few others in other parts of the country. Expect a bare minimum of 4-6 weeks for basic work, probably much longer.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Ship to Al Reed in So Cal. It's worth it..
'63 356 S90 Ivory/Red '70T coupe Burgundy/Tan '71 914 Canary Yellow '72 Datsun 240Z Orange/Black '65 Chevy C10 shortbed fleetside Butternut Yellow |
Harvey Weidman at Weidman's Wheels in Oroville, CA. He is the standard by which all are compared. The only problem is he is busy and it could take a while to get your wheels back. If you have another set to run on, or your car is apart being restored (like mine) then time may not be a real problem.
'71 914-6 #0372 '17 Macan GTS |
Hi - how long do you estimate Harvey will take to refinish a set of 80's 16" Fuchs to factory finish?
Regards, Steve |
Driver, not Mechanic
I'm curious why it takes so long. Is it the tools (only one set and very expensive to get another one) or the craftsman (skilled hands, takes years to perfect, haven't taught any new blood) ?
Harvey did fix one of my wheels, took about 4 weeks, but that's through the body shop. Maybe he prioritized it. |
Recreational User
I've used him to refinish two sets of Fuchs, one set in 2008 and one in 2013. The first set took 5 months, the second set took 9. He'll give you a rough estimate when you call, but you should take what he says and double it.
