Hi all, newbie here. 1973 911s targa that Mark Allen restored. Is there a reference on alignment of high and low beams on the 5-screw Bosch H4 units? Googling gave me everything but that...thanks all, hope everyone's running cool.
I searched the forum and found a thread that referred to this site with a procedure:
Daniel Stern Lighting Consultancy and Supply Hope this helps.
Dave 1985 Factory Turbo-Look Coupe 2011 Cayman S 2012 Audi S4 |
I used Sterns instructions when I installed my H4s a few years back and was pleased with the results
87 Carrera Coupe Black on Black, H4 Headlights, Nurburgring Sticker |
If your headlights have five screws you have H1 headlights. Follow Stern's instructions .
On the headlight glass you can see which screw is for vertical, horizontal, high and low beam.. H1s have separate reflectors, one for low beam and one for high beam. Last edited by donporfi; 08-09-2015 at 10:33 PM.. |
You may have alignment information in your owners manual, if you got one with the car. H1s have separate adjustments for the High beam reflector and the low beam reflector.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Thanks all, I just took one out (H1s) and made a little drawing of where each screw goes and where the pivots are. It's a little wonky how the pivots work, but knowing what direction things are "supposed" to be moving helps get it into alignment. I'm a light freak so of course that is the first thing I took a screwdriver out for on this beauty. The US-spec lights only are in the manual.
Thanks RSTarga - wow, you have a 73 since new? Amazing (and smart). Tell me about RS MFI specs?
