Hey guys:
Five minutes into my first-ever spark plug change on my '83SC, and I find this spring in the engine bay, just hanging out by cylinder #3. Any idea what it could be from?
Looks like a throttle return spring.
Platinum Member
First check throttle return.
Might help others if you post year & model.... |
sudo apt-get purge 930
^^^ What they said.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Tks!
Sorry, '83SC, noob mistake...
Can I assume Bentley will walk me through replacing this spring? And if it is the throttle return spring, what symptoms should I be seeing on the car since it's unattached? I have been experiencing high idle, but that sounds coincidental... |
Southern Class & Sass
It attaches to the throttle console. Follow the linkage to the back of the engine, which obviously is facing the front of the car.
Dixie Bradenton, FL 2013 Camaro ZL1 |
one end of the spring to the throttle plate bellcrank top hole, other end to the tab on the underside of intake tube #3 on CIS car.
HTH Thor ![]()
1978 SC coupe #1834 |
Platinum Member
