-   -   Which spark plus to use with Perma-Tune? (http://forums.pelicanparts.com/porsche-911-technical-forum/757191-spark-plus-use-perma-tune.html)
Bruno911 06-21-2013 05:56 AM
My 77 911 2.7S has a Perma-Tune spark ignition box. Does anyone know which spark plugs to use? Underneath the model.
http://forums.pelicanparts.com/uploa...1371819369.jpg
T77911S 06-21-2013 06:03 AM
bosch copper plugs. (W5...)
i would really consider replacing that with either an MSD unit or the original bosch unit.
(and coil)
Bob Kontak 06-21-2013 06:13 AM
Don't gap the plugs to sixty thousandths of an inch because you read where that will work.
Keep the gap much closer to stock.
Also, on the Permatune box............. What T77911S says. Replacing the P Tune is good insurance you will not be stranded. It's a roll of the dice if you keep it on - and it may go forever - some do, many don't.
Joe Bob 06-21-2013 11:04 AM
They don't call them PermaCrap for nothing.
Use the cheap, copper plugs...you can find 3 or 6 pin rebuilt Bosch units for 3-400.
T77911S 06-21-2013 11:13 AM
if the W5 fouls on you, go with a W7
manbridge 74 06-21-2013 11:14 AM
I believe the factory used Perma-Tune in the mid 70s...
http://forums.pelicanparts.com/porsche-911-technical-forum/573186-permatune-3-pin-box-factory-1975-a.html
Older boxes are apparently robust and repairable.
