wrxnofx's Avatar
Any Advice on Removing Piping Between Front Fender and Panel Below Windshield?
As the subject says, I am trying to remove the piping (900-631-115-90) between the front fender and the panel below the windshield where the wipers come out of. I managed to get almost 1/2 of it, and now it has partially torn, leaving the part that wedges between the panels still in there. Any advice on how to get this stuff out?
Old 06-21-2013, 07:40 PM
you have to at least loosen the two hex head bolts up under the rear part of the front fender.
Pelican sells replacement welting, I think there are two thicknesses available.
Just replaced it on my 930, and the new stuff looks great.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 06-21-2013, 07:51 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Agree - loosen bolts inside door - and extract. Get the fat ones vs skinny.
1981 911SC Targa
Old 06-21-2013, 08:18 PM
Just curious, why are the fat ones better than the skinny?
Steve B.
1972 911t
1999 328is
Old 06-22-2013, 06:48 AM
moneymanager's Avatar
What year is your car? On some of the earlier cars the fender may be tacked in place at the rear so that removing the welting is nearly impossible. There is debate about whether the factory ever did this but in my case I believe they did.
My project took about ten hours longer than I thought it would!
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 06-22-2013, 07:36 AM
wrxnofx's Avatar
Thanks for the feedback, everyone. It's an '87 model year. I'll give this a shot.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 06-22-2013, 10:35 AM
wrxnofx's Avatar
Worked like a champ!
Old 06-22-2013, 11:33 AM
Recreational User
porschenut's Avatar
Those 2 fasteners seem like they're difficult to get to. What combination of tools and/or extensions did you use to get at them?
Old 06-22-2013, 07:46 PM
wrxnofx's Avatar
Porschenut, for the bolt furthest towards the back of the car (the one less recessed) I used a 3/8" drive ratchet and 5mm hex socket. For the one really recessed in there (2nd from the back of the car) I used the 3/8" ratchet, extension, universal joint, and the 5mm hex socket:
Loosened each of them a few turns, and that created enough of a gap for me to be able to pull the old, perished one out and insert the new one.
Old 06-22-2013, 08:27 PM
Recreational User
porschenut's Avatar
Thank you sir! I need to do this on my Targa.
Old 06-23-2013, 11:13 AM
viking644's Avatar
You sir, are my hero. This was exactly the information I needed, and have been searching for.
Old 12-01-2015, 06:46 PM
Just to be clear, for those of you needing to remove the entire seal you will also have to loosen the first 2 bolts located inside the front trunk that secure the fenders. Loosening just the 2 bolts inside the doorway worked for wrxnofx as he only had to remove rear half. Also use of a soapy water mix will greatly aid the insertion of the new seal.
David Yerkes
1987 911 Targa - GP White
Old 12-02-2015, 05:04 AM
wayner's Avatar
Can someone post a pic of a factory seal with the hood up?
I'm trying to figure out what to do about the flat part that extends into the trunk.
Trim it? Glue it down?
SOLD - 914 wide body hot rod
Old 12-02-2015, 05:49 AM
universeman's Avatar
That part is supposed to go down into the groove between fender and frunk...and ends at the hood seal. Sits flush with the body panel, just like the other part, when it's in correctly. I can't get mine to do it, no matter how much I loosen the fender. I try to cram it down in there but no go.
My recommendation if you run into that issue would be to trim off the bottom of it so it's shorter and will fit better into the crack, if you can't get it to go all the way down.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 12-02-2015, 02:33 PM
wayner's Avatar
Thanks.
My car arrived in boxes so I've never had a chance to see it in place.
Old 12-03-2015, 05:23 AM
