brads911sc's Avatar
But if I didnt want to get into major mods. Just adding 98 mm P/C 9:5 compression... Already have the EFI/Recurved Dizzy.
Would I be better off with the standard CIS cam or 964 Cam to get max Torque from 2k-5k Rpms?
Thanks!
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 10-15-2010, 07:03 AM
Mocha BAP
Staylo's Avatar
Send a message via Yahoo to Staylo
3.2ss
I recently completed at 3.2ss build as well. Since the car is a '79, and I live in CA., CIS had to be retained. I went with the following:
9:5 98mm JE/Mahle P&C's
964 Cams
Electromotive Crankfire Ignition
SSI's w/ Dansk 2/2
'79 Large Port CIS with a little TB work
Dyno showed 235 hp and 210 tq. at the wheels. Peak HP @6450 and peak tq. @5100.
If you don't have Cali type smog laws to deal with, use a more aggresive cam with PMO's and 260 rwhp is quite possible.
I love the results, but costs can approach 3.6 territory. If I had to do it again....Hmmm....
Scott
71 911T Coupe 3.0 Looks stock
79 911SC Coupe 3.2ss Nothing stock
02 996 C2 Cab Mostly stock
06 955 CTTS Super P!G
Old 10-15-2010, 09:56 AM
Happiest when Tinkering
gsmith660's Avatar
This is all good info 8 year old thread or not my plans are a 3.2 SS 8 to 1 C/R 1 bar boost EFI EDIS water/meth injection twin plug G50 tranny and all so I liked all this info.
Old 10-15-2010, 11:18 AM
brads911sc's Avatar
Do you lose any low end grunt with 964 cams?
964 Cams
SSI's w/ Dansk 2/2
Old 10-15-2010, 12:49 PM
Mocha BAP
Staylo's Avatar
No. It actually has a much stronger, flatter torque curve throughout the rpm range.
Scott
Old 10-15-2010, 01:32 PM
I'm pretty sure you mean 9.5:1 compression ratio. Yes?
9:5 (works out to 4.5:1?) wouldn't get out or it's own way but it would probably run on kerosene.
I know, just a typo, but got me thinking.
Mine is 9.5:1 with CIS.
Old 10-15-2010, 02:02 PM
Mocha BAP
Staylo's Avatar
Yes, tcar
Old 10-15-2010, 02:15 PM
964 Cams
SSI's w/ Dansk 2/2
How do you get away with running SSIs, the '79 had a cat? Also, are you running single or dual plug (I'm assuming single).
Oh, and this with PMO's is my end goal... but a long way off with government pay. I probably won't go more aggressive with the cams as its mostly a street car. Nice to have an idea of what numbers I could expect.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 10-15-2010, 04:59 PM
Mocha BAP
Staylo's Avatar
Yes, single plug.
For smog test, I have a bursch style set-up with a cat welded in. It's loud, but it does the job for one day. I then plug in the smog pump (without actual plumbing) for show, and it's good to go.
Scott
Old 10-15-2010, 05:17 PM
I am looking at building a 3.2 or 3.4 ss using a 3.2 crank and rods with 98mm bore. Those who have posted above have you guys done the treadmill for some results?
I would like to EFI, but budget police might keep me with the CIS. I have spoken with Steve at Rennsport, and Pete and Andial and the big gains are going with a MOD-S type of cam and EFI.
Both said easily 230-260 range would be attainable. Can you guys verify that with your setups?
Thanks,
John
Old 10-23-2010, 08:51 AM
964 Cams
SSI's w/ Dansk 2/2
again....Hmmm....
Hi,
I have a euro Carrera 3.0 that I have just blown the engine on and are looking to do a 3.2 SS retaining the CIS.
What difference does electromotive crankfire ignition make??
Just to clarify did you have 235hp and the wheels or the crank, as 235 at the wheels is a 20% boost over stock.
Do you have a copy of the dyno sheet - I'd be really interested to see please.
Thanks in advance.
Old 03-21-2013, 05:26 PM
