Urgent cam tower question!!
I just received some 78-79 cam towers from a pelican gentleman. Fed ex
mine (from an 88 3.2) are stamped: 964-105-111-0r
the 78-79 ones i received to replace those are stamped: 901-105-111-1r
they sure look the same , and both are 4 bearing
are they completely interchangeable??
Help!! Trying to finish my long block tonite!!
Frank
Old 06-25-2013, 08:17 AM
356RS's Avatar
Make sure the cam bore is 49mm for the later 4 bearing cams. Early cams are 47mm. I would have thought a 78 SC cam tower casting number to be 930 not 901.
Mark Jung
Bend, OR
MFI Werks.com
Old 06-25-2013, 09:09 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Google 901-105-111 and it might help you figure it out.
Lots of PP thread on it. This on match the full number; http://www.early911sregistry.org/forums/showthread.php?54657-Info-on-unstamped-engine-case-901-105-111-1R
Who Will Live... Will See
Old 06-25-2013, 04:33 PM
thanks 356 and jj i figured it out its fine and fit well as i put it together tonite.. umfortunately i seem to have lost one of the cam bolts and the big washer...crapola!!
cheers frank,,,
Old 06-25-2013, 07:28 PM
