Ubi bene ibi patria
Part No. for this ground cable?
![]() I have been unable to locate a part # for this braided ground cable - it is about 6" lg. x 1/2" w. with approx. 1/4" dia holes at each end. It connects from the crankcase to the blower housing (1970 2.2L engine). It is in bad shape & requires replacement. Any suggestions welcome. Thanks in advance. Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
napa auto parts carries ground straps. no need for a porsche part.
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
No need for it to be a braided one either.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Schleprock
If you really like the flat braided style, its the same as the strap that connects the trans to the body under the car.
I agree with the other guys. Get a simple ground strap at your local auto parts store. Can even make your own with heavy gauge copper wire and solder some cable terminals on the ends.
Kevin L '86 Carrera "Larry" |
braided strap
The strap from the trans to chassis is 999 611 920 20
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
ROW '78 911 Targa
I have the correct tinned, braided belden cable for the early cars used in the CDI wiring harness. If it's the same diameter stuff, I can build you one. (It's only $480 a 100 foot roll...)
PM me if you want one. I'll need some measurements. Dennis Edit; Looks to be the thicker ground strap was used. (Now that I'm not looking at it on my phone...) The link supplied above is what you probably want. Much thinner strap was used on later model year cars. Last edited by timmy2; 06-25-2013 at 04:55 PM.. |
i have a bunch of leftover 4g copper wiring from various audio installs. give me the length you need and i can make you a custom cable, including properly crimped terminals, pretty cheap.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
