'73 911T Fuse Panel Replacement ?
Doing a bit of electrical sorting on some "interesting" wiring the prior owner did on my '73 911 (uhhhhh no, wire nuts and twisted together wire with glue really are not the best plan...) and as I was removing wires to clean from the top 10 fuse box one end of it crumbled and fell apart. Darn.
Searching Pelican for a replacement, I am not sure they have one. The item that seems like it might be what I need has scant description and no photo. Expensive too. Any ideas on a source for these? |
I've read where others have picked up later year fuse panels and cut them down to fit.
The other option is to build an ATO fuse panel to replace it. (More reliable) |
The one on Pelican is correct. 911-612-086-00-OEM
Porsche 911 Charging System - Page 2 If you go aftermarket, you have to add jumpers to make sure that the connections match the straps between terminals on the rear of the original. DC Auto has a used one. |
a guy on here builds an ATO fuse panel for later years and has built or is planning to build one for early cars
BTW - I found some twist wire connectors from a PO on my '73.5T |
| All times are GMT -8. The time now is 04:28 PM. |
