'73 911T Fuse Panel Replacement ?
Doing a bit of electrical sorting on some "interesting" wiring the prior owner did on my '73 911 (uhhhhh no, wire nuts and twisted together wire with glue really are not the best plan...) and as I was removing wires to clean from the top 10 fuse box one end of it crumbled and fell apart. Darn.
Searching Pelican for a replacement, I am not sure they have one. The item that seems like it might be what I need has scant description and no photo. Expensive too.
Any ideas on a source for these?
Terry
Old 06-25-2013, 05:41 PM
ROW '78 911 Targa
timmy2's Avatar
I've read where others have picked up later year fuse panels and cut them down to fit.
The other option is to build an ATO fuse panel to replace it. (More reliable)
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-25-2013, 05:46 PM
E Sully's Avatar
The one on Pelican is correct. 911-612-086-00-OEM
Porsche 911 Charging System - Page 2
If you go aftermarket, you have to add jumpers to make sure that the connections match the straps between terminals on the rear of the original. DC Auto has a used one.
Ed
1973.5 T
Old 06-26-2013, 07:25 AM
AutoBahned
RWebb's Avatar
a guy on here builds an ATO fuse panel for later years and has built or is planning to build one for early cars
BTW - I found some twist wire connectors from a PO on my '73.5T
Old 06-26-2013, 01:27 PM
