convertible top control fuse
There are 2 fuses for the convertible top. Position 3 in the fuse box, a 25A fuse. There should be also a 2.5A fuse for the convertible control unit somewhere in the luggage compartment. But where???? Thanks in front!
http://forums.pelicanparts.com/uploa...1372272142.jpg |
Is there somebody who knows? Thanks.
It's not in the plastic fuse and relay carrier , it's an inline fuse which should be a red wire You know the glass type twist fuse holders . Rummage around the wires by the box you'll see it.
Thanks AVDCAV, I know, I found the other 16 Amps for the radio. But cannot find the 2.5Amps for the convertible top control.
Has anyone found this? I would like a tip on where the 2.5 amp fuse for the convertible top is located.
I have an 89 Cab and found both the top and radio fuse, in-line, below the fuse panel and under the fuel filler next. There was a plastic zip tie holding the wires and I needed to carefully cut it to really get to them. They seem to be very hard to access.
Fuse location.
Correct. |
Okay, any tips on how to isolate it? How do I know I have the right thing?
Where does it attach to the main fuse box? |
If I remember there was a large in-line holder labeled radio and I think the smaller one had "c" which was for he top
Ok cool - found a photo from another Pelican:
http://forums.pelicanparts.com/porsche-911-technical-forum/813632-cabriolet-mystery-fuse-top.html |
| All times are GMT -8. The time now is 01:50 PM. |
