convertible top control fuse
There are 2 fuses for the convertible top. Position 3 in the fuse box, a 25A fuse. There should be also a 2.5A fuse for the convertible control unit somewhere in the luggage compartment. But where???? Thanks in front!
Is there somebody who knows? Thanks.
It's not in the plastic fuse and relay carrier , it's an inline fuse which should be a red wire You know the glass type twist fuse holders . Rummage around the wires by the box you'll see it.
Thanks AVDCAV, I know, I found the other 16 Amps for the radio. But cannot find the 2.5Amps for the convertible top control.
Has anyone found this? I would like a tip on where the 2.5 amp fuse for the convertible top is located.
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
I have an 89 Cab and found both the top and radio fuse, in-line, below the fuse panel and under the fuel filler next. There was a plastic zip tie holding the wires and I needed to carefully cut it to really get to them. They seem to be very hard to access.
1989 Cabriolet 1970 911E Sold |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse location.
Correct.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Okay, any tips on how to isolate it? How do I know I have the right thing?
Where does it attach to the main fuse box?
If I remember there was a large in-line holder labeled radio and I think the smaller one had "c" which was for he top
