wwest's Avatar
CDI location...
'88 Carrera, where is the CDI located. And I see no "trigger" wiring from the distributor...Crank position sensor...?
Started then died within 2-3 seconds, now cranks but no start. Fuel pump runs with jumper bypass to fuse, no spark from coil.
Tach does not "jitter" while cranking.
Old 06-27-2013, 09:47 AM
304065's Avatar
There is no CDI on an 88 Carrera, the coil is switched by an IGBT on the Motronic board itself.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-27-2013, 10:24 AM
Friend of Warren
DME box is located under the driver's seat. Right next to it is a small, black cube, which is the DME relay. It also controls the fuel pump. I suspect the DME relay has gone bad in your car.
Kurt V
Old 06-27-2013, 10:27 AM
wwest's Avatar
Strange..
Fuel pump was getting power during cranking but no sparks..
Disconnected battery ground, count to 10 slowly, reconnect, crank...START...!!
What...??
Old 07-07-2013, 01:11 PM
RETIRED
Joe Bob's Avatar
Check the voltage at the alternator with a DVM.
2012 ML350 3.0 Turbo Diesel
Old 07-07-2013, 04:52 PM
wwest's Avatar
Happened to this car about 15 years ago, battery began to boil, drove home with all electrical loads ON.
New battery and alternator back then, Squire's.
I have a Fluke DMM and an O'scope.
Old 07-07-2013, 06:01 PM
wwest's Avatar
Strange..New DME relay but still no start. Biopsy on old relay (non-OEM) indicated it was in good condition.
Wiggled a few of the fuses in the front, can started right up.
Symptoms: sometimes no start, sometimes start but stops with accelerator depression, sometimes start, run in place for a minute or so, drive away.....
Old 08-05-2013, 12:25 PM
Banned
A Spal fan, triggered by an over/under voltage switch, aimed at the fuse panel = problem solved.
Old 08-05-2013, 12:36 PM
wwest's Avatar
Originally Posted by Ronnie's.930 View Post
A Spal fan, triggered by and over/under voltage switch, aimed at the fuse panel = problem solved.
Old 08-05-2013, 02:30 PM
