scarletbegonias's Avatar
68 Signal Light help
Hi - it seems like every year before inspection I struggle with getting all the lights working. And I'm having problems again this year (see photo).
- confirmed with a test light that there's power going to wire marked 1
- signal bulb holder (2 on picture) works on the other side's light assembly
- all the other bulbs in this light assembly work
I've tried cleaning all the connections and bending the bulb holder contacts to make a better connection, but it still won't work. Any suggestions appreciated. Thanks.
Howard
1968 912 Targa
memories
1977 911S, 1968 BMW 1600, 1976 BMW 2002
Old 06-30-2013, 09:04 AM
Did you check to make sure the bulbs are actually working? I've chased a similar issue and found it was simply the bulb.
John Thompson
Eugene, Oregon
Old 06-30-2013, 01:21 PM
Could be oxidation where the contacts are riveted together. Either the + or - side. This is becoming more common every day as these already old housings get older. Jumper wires and patience to identify, cleaning and a dab of solder to fix.
Old 06-30-2013, 05:13 PM
