Hand Throttle Parts, Can it be MADE??????
Hi all from Australia, can the parts numbered 79 and 80 below in the diagram be made???(mainly part 79),the lock screw(part 80) could come from the local hardware store , any ideas as I have purchased a complete hand throttle off a fellow pelican as well as a new plastic control fork??(you know, the part that breaks after becoming brittle in the tunnel)and new hand brake boot cover. I have put a WTB in the parts forum for 10 days but no responses,no parts here in Australia,Sooooooo,I`m wondering if it could be made (part 79) any ideas would be much appreciated.
Many Thanks From Oz
Old 07-04-2013, 04:07 AM
Discseven's Avatar
I say any part can be made provided you have the tools to make it --- or the resources. Those are small parts... should be relatively easy of inexpensive if you outsource.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-04-2013, 04:45 AM
I would rather be driving
jpnovak's Avatar
Yes, its just a collar with a set screw. Find one the right diameter for the throttle rod. I think its 4mm.
Old 07-04-2013, 04:46 AM
Set screw - hardware store.
Collar - Make from round steel bar stock.
Plastic fork - I machined my own for my '75. PM me an e-mail address and I'll send you the drawing I used.
Old 07-04-2013, 06:07 AM
Thanks for your replies evreyone,this is a great help, as I have not seen the parts up close, (I have some pictures)
fanaudical, many thanks for the round bar idea, also for your offer on the plastic fork, I did buy a new fork though Regards Brett L
Old 07-04-2013, 01:07 PM
Send a message via Skype™ to Porboynz
You could use the brass insert from a suitably sized electrical connector (the so called chocolate block) Cut the plastic off and then cut a slot in the side of the brass connecter that has the screw threaded into it. Easy peazy, skill knife and hacksaw and you are done.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 07-04-2013, 09:48 PM
Turbofrog
smurfbus's Avatar
I used a kit for wire ends. I took some time to machine it right with hand tools but it has hold fine for some time now.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 07-04-2013, 11:30 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Check with a motorcycle repair shop....they have tons of different size and shape wire fittings that either set screw on...or are soldered.
Bob
Bob Hutson
Old 07-05-2013, 12:22 AM
