Porsche G50 52 advice neede...
Hello! I'm building a Ford GT40 replica and am using a Porsche G50 52 transaxle. It seems my reverse switch mechanism inside the trans is not working properly. When I shift into reverse the pin that inserts into the switch should move away from the trans and actuate the reverse switch. It doesn't move when put into reverse. The transaxle was new 12 years ago and modified to work in a mid-engine vehicle. The differential was changed, it was plumbed for external oil circulation and the 1st and 2nd shift forks were replaced with stronger ones. The trans was not installed after the mods and sat until I purchased it for this project. Can someone who is familiar with the inner workings of the G50 52 advise me on this? Could some part have been left out or mis-installed inside the trans during the process of the modifications that could cause the reverse switch pin not to move? Could the wrong length pin have been installed? I'm hoping a G50 52 guru will appear and tell me a simple fix for this problem. I have a sexy reverse light I built and the reverse switch also supplies power to a back-up camera system I've installed. Because it is a cable shift mechanism, a separate external switch will be difficult to engineer. Thanks for your help!
Kim
Old 08-01-2019, 04:25 PM
G50
If the pin is in the gearbox and the correct switch it should activate the switch, If I remember correctly on the reverse selector shaft there's a machined ramp in the shaft that moves the pin, unlike the 915 that has a removable roll pin to move the switch.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 08-02-2019, 04:30 AM
I see. If that's the case, it would seem difficult to install it wrong...but of course I could be wrong. Anyone else got something?
Kim
Old 08-02-2019, 06:16 AM
Chain fence eating turbo
I'd say the expert would be Matt Monson here for Porsche transaxles.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, depending on mood , Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-02-2019, 12:08 PM
