Wow the sunroof is easy to work on!
For anyone contemplating digging into the sunroof I highly suggest it!
I was hesitant to touch it after dealing with other sunroofs that had microswitches and several relays. Access is not a problem thanks to the handy zipper in the headliner.
It may seem like some sort of magical device but really it has only a few moving parts and a grand total of 2 wires in the roof part.
After taking it apart, cleaning out all the 37 year old grease, adjusting it a little, fixing the sheared off coupling with several tight wraps of black 1" gorilla tape (hey, it works and saved $131) and lubing it with a little silicone spray it works flawlessly.
Here are a few helpful links:
Sunroof cable repair and new seals 87 911
Pelican Technical Article: 911 Sunroof Repair
Sunroof seal replacement any tips before I begin.
Porsche 911 Sunroof Parts - Page 1
Now it's time to start on the less glamourous windshield washer system
Old 07-07-2013, 11:55 PM
Discseven's Avatar
The first link is great Jr! (I have a Targa but can still appreciate a well done documentation of a project.)
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-08-2013, 04:26 AM
AutoBahned
RWebb's Avatar
Thanks for the thread compilation - did your 912E differ much from the '87 and later cars in the threads?
Old 07-08-2013, 12:38 PM
The rails were a little different but it all appears to work the same way. From what I've read they didn't change it much through aircooled production.
Old 07-08-2013, 12:56 PM
Senior Member
Jdub's Avatar
So does the top just fly open and shut now?
'78 Targa in Minerva Blue
Old 07-08-2013, 01:34 PM
On Tour
MMiller's Avatar
I also used the first link when I refurbished mine a few weeks ago. I had it repainted to fix the clear coat and replaced the felt seals. Not a hard job and it sure looks much better.
regards,
- 2018 Cayenne S 958.2
- 1988 Carrera 3.2 Coupe Marine Blue (SOLD)
Old 07-08-2013, 02:57 PM
theiceman's Avatar
my budies car scratched the whole roof to pieces when he opened it a few times. po had not opened it
can this be repaired or adjusted with above links or is be looking at major bucks. i am willing to help him as he isnt mechanically inclined but dont want to take it apart for nothing.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-08-2013, 04:37 PM
If it opened it means the motor is working. Not sure what would have caused the scratches - maybe it needs to be adjusted. New cables are expensive at $140 each, but sounds like that is not the issue. Paying someone to fix it would be expensive (I think) simply because there is a lot of adjusting/fiddling around to do to get it to work smoothly. Like the original poster said, it's a fairly basic mechanism and easily accessible.
Old 07-09-2013, 01:03 PM
On Tour
MMiller's Avatar
The Bentley breaks it down fairly well so you might look at that and see if you want to fool with it for him. It sounds like it might not be "kicking down" properly when first opened to cause it to be getting scratched.. Remove the inner head liner then open slowly and maybe you can see where the problem lies.. Be careful though I don't think you will be able to open it very far with the inner head liner slid back in the hole.
Old 07-09-2013, 02:07 PM
