Anyone ever repaired a Sport Seat bolster foam?
Have this pair of mid year sport seat cores. The foam is still chunky and has good shape, except for the missing worn driver's left side. I was looking for an option to the high cost of seat foam. Has anyone done their own repair? I was told, a piece of foam could be sectioned and shaped, with a electric knife and sander. I'd appreciate any feedback.
Old 07-08-2013, 11:00 PM
Discseven's Avatar
I watched an upholsterer cut foam with an electric carving knife --- turkey knife. Then sand it to smooth the contours.
On a leather note...
Not sure how you are going to approach the middle section of your seats... but mine has the perf pattern in the leather. Looked for this perf'd leather and couldn't find so I created a paper template and punched the holes one by one. Sounds insane but doesn't really take that long. Used calf skin --- very soft. That skin has to be backed up with a permeable membrane so it has some substance while allowing air to easily vent through it.
Good luck on your seats!
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-09-2013, 05:08 AM
I did that this spring, on an '84 sport seat.
Find some good foam, preferably the same type (density). Cut the defect to a square (ish) shape, and glue the new foam in. Then electric knife, sandpaper, scalpel, etc, whatever gets you to the right shape.
After that there is the risk that the glue line is harder than the foam. In that case, find a thick, soft fabric (I used fleece) and glue over the whole bolster. This will "hide" the glue line and hold the foam much better. It also brings some welcome volume to the foam that is most likely flattened somewhat, and will prevent unsightly creases on the leather cover, that come from lack of foam volume.
Old 07-09-2013, 05:58 AM
Discseven, Thanks for the input.
GeorgeK, Great job...wish I had your skills.
Old 07-09-2013, 07:31 AM
Capitalist and Patriot
911Freak's Avatar
Draco did I complete, step be step sport seat RE-upholster thread not too long ago. Search and ye shall find
Old 07-09-2013, 08:11 AM
Reiver
Reiver's Avatar
Just had my Recaro's recovered...on the bolster he cut the top half off horizontally (down to solid original foam) and used glue to attach the piece he shaped...looks/feels perfect.
Old 07-09-2013, 11:56 AM
Thanks for the info guys. The post I saw for Draco, was a complete upholstery with standard seats.
Old 07-10-2013, 08:01 AM
rnln's Avatar
wait for draco to come in. He can have some good advices. He did his sport seats.
Fat butt 911, 1987
Old 07-11-2013, 12:55 AM
