tailwind22's Avatar
Consensus on bouncing oil pressure needle
I know this has been discussed before but is there a consensus on the cause of a bouncing oil pressure needle. Seems like I recall the first thing to try is cleaning the electrical contacts at gauge and sender and second is bad sender. Thoughts? The sender is not a fun project with air conditioning.
Old 07-14-2013, 07:02 AM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
I agree with your approach.
I went through this same problem a few months ago, and unfortunately it turned out to be the sensor. As you say, this job is no fun with a/c, but it is not difficult, just time-consuming to disassemble everything one needs to remove to get to the sensor and to reinstall these items.
I also tried to remove the sensor using some of the methods proposed in this forum to minimize the number of parts removed - My advise is to not waste your time, as the connecting pipe and fittings are too fragile to risk. Do it by the book.
Old 07-14-2013, 08:41 AM
Member 911 Anonymous
DRACO A5OG's Avatar
After an AX, my wire broke loose at the sender unit on top, re-soldered, issue solved.
+1, Clean and polish the negative ground cinnection on the gauge as well, it will not hurt.
'85 Carrera Targa
PCA/POC
Old 07-14-2013, 09:56 AM
Eva
911SauCy's Avatar
If your car is a '78 like mine, and this is occurring whilst at temp after/during hard acceleration or cornering...the gauge is working perfectly.
You need to perform an Oil Pressure Relief Valve update and install a sump screen.
The needle bouncing is detecting cavitation of the oil due to need for better OPRV spring tension and the sump trying to scavenge sloshing oil.
Otherwise, enjoy your electric endeavors
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 07-14-2013, 10:44 AM
tailwind22's Avatar
So this thought would apply to 78 and older turbo blocks?
Old 07-14-2013, 03:35 PM
