Driver side front blinker
It won't work.
The right side (front and back work great). When I signal left the rear left has a very fast blink... but the front won't go. I confirmed the bulb is OK. Fuse is fine..replaced it with the right and same symptoms. Any idea where to search for a problem?
1978 911 Turbo Cab Conversion w/1987 930 Engine |
So many places, I guess you swapped the bulb from side to side? Any voltage at the lhs? Corrosion on the brass contacts, dodgy earth, corrosion on the alloy housing, problem connector into trunk area, could be anything.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
