-   -   Re-using engine oil (http://forums.pelicanparts.com/porsche-911-technical-forum/760972-re-using-engine-oil.html)
C4UKPOR 07-15-2013 06:37 AM
Re-using engine oil
I serviced my SC a week ago and obviously filled with new engine oil. I may have to drop the oil again shortly to fix a leaking cam cover. Is it OK to collect this oil and re-use?
Discseven 07-15-2013 06:39 AM
I would... while making sure it doesn't get contaminated along the way.
livi 07-15-2013 06:41 AM
Yes.
GH85Carrera 07-15-2013 06:42 AM
In theory yes, but I would never do it.
Can you be 100% sure there is no grit or dirt at all in your oil collection system?
I know 10 or 11 quarts of oil is expensive but I just can't see taking the risk. But that is just me and my engine.
Jesse16 07-15-2013 07:14 AM
Be a good excuse to have two of those little valve things instead of drain plugs. Then you could control the discharge and put it in 1 or 4 quart clean containers. $50 to $100 worth of oil savings would buy 2 for sure.
CCM911 07-15-2013 07:16 AM
I see nothing wrong with your plan, provided you capture the used oil in a very clean container. No big deal. Folks do it all the time.
Smoove1010 07-15-2013 07:25 AM
According to diagrams I've seen, oil from the tank is pulled directly into the engine. It's filtered only on the way back into the tank after making the circuit.
It's very tempting to re-use all that oil, but I can't shake the image of those tiny orifices in the piston squirters. I'd go to some pretty extreme lengths to insure that the oil I was putting back was perfectly clean.
Good luck,
GK
boyt911sc 07-15-2013 07:46 AM
Filtration.........
I would suggest using a ladies nylon stocking to filter the used oil. If the oil has only a hundred miles or less and uncontaminated, there is no reason to dispose it. The oil has several thousand miles recommended usage before any change oil. The decision is all yours, there is no right or wrong.
Tony
JAR0023 07-15-2013 08:47 AM
How about not drain the oil in the first place? When you say cam cover I'm assuming you're talking about a lower valve cover. Lots of folks here have confirmed completing valve adjustment without draining the oil. Lift car only on one side and what oil is in the sump will flow to other side. You may have lose a little oil but not enough to complain about. Just top up once valve cover resealed. -J
RWebb 07-15-2013 01:12 PM
coffee filter
Ronnie's.930 07-15-2013 01:26 PM
I re-use oil all the time (have for 25-30 years) - I catch it in a clean pan and then transfer it to clean bottles using a paint strainer in a funnel - never had a problem.
boxster03 07-15-2013 03:48 PM
I sure would - best $1.99 you will ever save - until the engine blows that is :eek:
nickelplated5s 07-15-2013 03:56 PM
We reuse ours...in a waste oil shop furnace.
teleski42 07-15-2013 04:18 PM
When you use the lady's nylon stockings is she wearing them?
RWebb 07-15-2013 04:24 PM
reusing 1 week old engine oil will hardly "blow the engine"
you do want to make sure no grit is introduced and a coffee filter will filter out smaller particles than stockings or paint filters
S2GART 07-15-2013 04:26 PM
I have never done it, but I would as long as the container you are using to catch the oil is absolutely clean and that you don't knock any dirt into it in the process of getting the oil out.
LuftWaffle 07-15-2013 05:03 PM
This is the correct answer to the OP's question. No need to drain a drop to pull a lower valve cover - just elevate that side!
Jerome74911S 07-15-2013 05:29 PM
Ditto. Been there, done that.
Nick Triesch 07-15-2013 06:14 PM
Wow! You better not reuse that oil! Your 35 year old car may not make it to 300,000 miles. Maybe only 250,000!!!! OMG!
Ronnie's.930 07-15-2013 06:18 PM
I've tried using a coffee filter recently when I was out of paint strainers and I couldn't get the oil to go through it (would have taken all night for one quart to pass) - must have been using the wrong filters? :D
