OK, I am not that good at electrical stuff, so I would be grateful for a few pointers here. The turn signal repeater lights in my speedo both come on dimly whenever the engine ignition is on. The actual outside turn signals all work fine but when I select left or right. the arrows are a little haywire, simultaneously flashing brighter on the side I am turning and dimmer on the other side but neither side ever goes out completely.
I have had the speedo out and cannot see any obvious wiring problems behind it. Could it be a turn signal switch problem? I don't want to just throw in a new switch and find that it wasn't the problem, so where should I poke around before that point?
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!. 1977 911S 2.7 to spend money on 2006 Tundra for acting grownup |
Hello
Had some issues with my turn signals also. First the would stay on all the time and only flash when I was using them to indicate a turn. Then the finally stopped flashing all together a couple months later. Replaced the relay behind the dash and now they work fine. Good luck
Pleasant Hill, California Weekend / Project - 1979 Porsche 911 sc Former in order of ownership: 1977 Scirocco / 1984 MkI GTI / 1981 Scirocco S / 1987 Scirocco 16V / 2004 Golf R32 / 1985 BMW 535i - Daily Driver |
JimmyVee.- Thanks for responding. Where is this relay located under the dash? I haven't been able to locate one.
Fleabit peanut monkey
Open hood. Turn blinkers on so they are engaged Reach your hand deep into the recess on the far driver's side upper corner of front hood area. There are relays up in there. Feel for the one that is clicking.
1981 911SC Targa |
You can get to the relays by removing the tach or other gauge. Feeling for the blinking vibration will lead you there in short order.
My indicators did a similar thing. The left would come on normally when the stalk swich was activated but the second and following pulses would show weakly in both right and left gauge indicators. Problem was a that the left front turn bulb was bad- also the back of the socket had pushed out - I fixed that with JB weld. I didn't try too hard to figure out the current flow that caused the indicator phenomena.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
Thankyou Gentlemen, that's a big help knowing where to look.
