Southern Class & Sass
Dixie's Avatar
Loss of power
Any most-likely items I should diagnose first?
I've put about 500 miles on my '88 911 after having it sit for almost two years. I simply put some fresh gas in it and it's been running fine.
Yesterday it lost power. I was almost to the track, about a 15 mile drive, and the RPM started dropping. It would only rev to 2K in second gear. It cut off more than once. It would start, but wouldn't rev. I checked for the obvious, such as a loose vacuum line, and found nothing. With nothing to lose I swapped in a spare DME relay. I got the car to start and made the last mile. The car barely ran and cut off just shy of the gate.
After sitting for 20 minutes I started the car. It ran great. After the event I drove home. It ran fine. I figure whatever the issue is will happen again, so I'd like to diagnose an fix whatever is failing now. Thoughts?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 07-13-2013, 03:33 AM
Discseven's Avatar
Might be the DME itself. Mine went bad and the car performed as you described Rob.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-13-2013, 03:56 AM
pete3799's Avatar
How old is the fuel filter?
Pete
79 911SC RoW
Old 07-13-2013, 04:03 AM
muck-raker
kidrock's Avatar
cylinder head temperature sensor
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-13-2013, 11:27 AM
Maybe failing fuel pump? Random symptoms, higher rpm volume issues at first, then as FP expires, nada.
Sherwood
Old 07-13-2013, 12:11 PM
Different breed of Porsche, but I had the same symptoms, years ago, on both a 944S2 and a 968. Replaced DME relay cured the 944S2 - it did not cure the 968, and I can no longer remember what the cure was, since that car ended badly and I've put a lot of those memories out of my mind.
GP White '84 Targa
Old 07-13-2013, 01:20 PM
Dixie's Avatar
Know what y'all? I'm thinking it was the DME relay. The problem has not recurred. In addition, it running a lot better since replacing it.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 07-16-2013, 03:53 PM
