Replacing Fuses
Apologize in advance for such a dumb question.
I just recently bought my '87 Coupe, and am starting to sort things out with it. There are a few fuses that are looking suspect and I'd like to change them.So how do you remove a fuse? Is there a fuse puller "tool" that is missing from inside my box, or do you just use a pliers to pull them? My fingers are too fat to get a good grip on them, so that won't work.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Push downward and life the top part out.
When you replace them try to find the ceramic based fuses. The plastic core fuses get soft with the heat and quit working in short order. (No pun intended) The ceramic fuses are tougher to find.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Also keep in mind that you can touch the metal part, and some of them have voltage running through them. Be careful, or disconnect the battery. They're not encapsulated like the modern plastic blade style fuses.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
No fuse puller that I know of, how about using a pair of needle nose pliers or hemostats? I went through my FP and cleaned the contacts of the fuse block along with the ends of the fuse. After installing I measured resistance across the holder to verify that I wasn't getting a voltage drop (which would be bad). Warren
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
cycling has-been
Look closely at the fuse holder. When you push down on the bottom tongue, and it acts like a spring to release the top.
(Install is the reverse of the above) Bill K also, with the ignition off, there shouldn't be any significant juice running through the exposed conductors.
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 07-18-2013 at 09:52 AM.. |
and don't be a real noob like me and drop the fuses down under the fuel tank... when I first got my car I had to change out a couple and can't tell you how many I lost in the nooks and crannies in the trunk until I got a good handle on how to remove them.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
Wow, THANKS for all the responses everyone! Your help is greatly appreciated!
