Ptoscano's Avatar
Send a message via Yahoo to Ptoscano
Turn signal not working
Guys need a little help. I have searched the forum and have not found an answer .
My turn signal lights work when car is off ( no key in ignition) lights are solid and don't blink. When car is on the turn signal lights don't work at all. I replaced the 3 spaded relay but to no avail. Any ideas ? Stalk ? Etc help is appreciated
Old 07-17-2013, 06:33 PM
winter
Winter's Avatar
They should be solid and not blink when car is off and stalk is activated.
Does your emergency flasher work, both when the car is off and on?
The flasher is part of the system, check for disconnected or loose wires to the emergency flasher.
Let us know what you find and if the e-flasher is functioning.
Old 07-17-2013, 09:05 PM
Ptoscano's Avatar
Ok thanks for info. I will check system. Is there a separate relay for hazards of is it built into the button unit ?
Old 07-18-2013, 05:15 AM
