ac blower fan
i was taking a 3 hour drive today and about an hour into my trip the fan quit blowing and the ac shut down in the high speed fan position...turning the knob to medium or low and the ac would start working again ...any ideas what i should check as to why the high speed isn't working would be appreciated and hopefully an easy fix...it had been working fine till today
thanks in advance
Jay
Old 07-19-2013, 05:49 PM
brads911sc's Avatar
Relay? Or switch? Should be able to test them..
Old 07-19-2013, 05:58 PM
thanks...i was thinking the same thing..
Old 07-19-2013, 06:44 PM
Discseven's Avatar
Jay, the AC speed switches rot out from age.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-20-2013, 05:10 AM
thanks for the replies...checking this morning with the engine off but the key switch on the front condenser blower and the clutch kicks in with the fan switched to high but the evaporator fan doesn't come on...turned down to low or medium and the fan runs....sounds like the switch?
Old 07-20-2013, 05:46 AM
wwest's Avatar
Much more likely a wiring connection burned open.
Old 07-20-2013, 07:51 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Isn't there a resistor thingie in the passenger floor board that complements the fan switch?
911-618-151-00
1981 911SC Targa
Old 07-20-2013, 01:53 PM
well i found the high speed fan wire that connects to the speed switch was corroded and burned so i cleaned up ALL the contacts and spliced in a new wire and blade connector and were back in business
thanks for the replies!!
Jay
Old 07-20-2013, 02:29 PM
Bob Kontak's Avatar
Nice Job.
Bonus points to wwest.
1981 911SC Targa
Old 07-20-2013, 02:43 PM
wwest's Avatar
Originally Posted by Bob Kontak View Post
Nice Job.
I need'm...
Old 07-20-2013, 06:25 PM
