911 oil line nut size??
86 911 what size is the nut size on the flexable oil line from fender oil cooler to main copper line under front fender?
I know its big lol, i dont have anything that big
36mm i believe. host sells special wrench for it.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Reiver
Right, I took one 34mm wrench and grinded it out to 36 just for that job...had an extra.
Speed Dog's Chauffeur
Big adjustable
Best are a big commercial grade adjustable wrenches(wide jaw Craftsman) from OSH about the same prices as the special wrenches. I have old Diamond Horseshoe wrenches but they are too expensive these days for most folks. Mine were perfect for installing my oil lines. EZ money on the end fittings. Also, one held the pressure relief firmly and the other broke the line nuts with ease to align everything for installation. Just do the inside nut then the outer nut and use "COPPER ANTI-SIEZE" on the threads. Remember that it is a taper seat AN Style fitting and does not require 200 ft-lbs of torque like pipe threads. Just M2CW but my block fittings broke loose with ease since they had factory torque & lots of PB Blaster soaking.
Pelican Parts - Product Information: PWE-2436RHW
Useful if you ever expect to do suspension work on your car, I have used this when dropping the engine. Stanley Proto J3536M Metric Thin Sevice Wrench 36mm - Amazon.com The one I use now because it's small, has a good angle to the head, and the handle is thin enough that you can put a jack handle over it as a cheater bar to get that first snap done, after that, the lines should come apart easily. Pelican Parts - Product Information: PEL-PW-OLW The wrench from our host.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
RETIRED
Big ass vise grips, channel locks and left handed metric crescent wrenches.....pipe on the ends, heat for the tough ones. MAPP versus propane.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
You can also go to a bike store and get a head stock stamped wrench for $7-8. I've consistently used these in combination with BigAss(TM) crescent and it has always worked.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
RETIRED
Park makes good bike tools.
awsome thanks guys im going to try and tackle it this weekend .
Im swaping it to my 82 coupe for some better cooling |
Got to have the big cresents & big channel locks
