RLL RLL is offline
1985 Porsche Blaupunkt radio repair
My Blaupunkt radio in my 1985 Porsche, 911 has very poor reception on both AM and FM. My initial thought is there is a problem with the antenna which I believe is embedded in the windshield or the antenna amplifier if there's one installed. Any suggestions on how to proceed would be helpful.
Old 08-02-2013, 07:56 PM
THE easiest thing to do is check the antenna for continuity or pull out the radio and hook it up to a known good antenna or piece of coax.
Old 08-06-2013, 09:49 AM
RLL RLL is offline
Does anyone know if there's a separate amplifier for the antenna?
Old 08-09-2013, 04:42 AM
Yes it should be by the hinge on the passenger side in the frunk. There is a 12v lead that is switched that goes to your radio, this is sometimes not connected or lost power, and may be your problem. It was put there to help the poor window antenna with reception. If you have a separate whip antenna it may work better without it.
Old 08-09-2013, 06:48 AM
RLL RLL is offline
Might this be mounted several inches behind the trunk hinge on the fender side? From what I can see there is at least 1 wire connected (there may be more but not visible) to a small black box. Also, what do you mean "there is a 12v lead that is switched"?
Old 08-09-2013, 06:02 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Amp.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-09-2013, 06:11 PM
