Inner Rocker Replacement?
Hi Everyone,
I'm looking for help on inner rocker panel replacement. I got the inner & outer rocker with the jack support & tube all ready. Here is the problem, the factory inner panel goes behind another panel that runs up the quarter panel. Now do I cut the panel right behind the jack tube and weld the two together. Or do I find a way to peal this piece back and try and slip the new one behind. Or should I cut a hole to get the jack tube out and put the new panel over this? Thanks For your help, chris |
Navin Johnson
I would remove the jack tube support, then peel back the part of the quater panel, then weld the inner rocker in, then replace the jack tube support etc.
I am in the middle of a similar project on my car. Look here for some pics of the rustoration. Im going to be adding some pics of my repairs to the torsion tube areas soon
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I think your project is alittle bigger, I like your web site (a lot of good pics)
Thanks |
