Sc quit, stranded, advice?
After 200 miles driving yesterday, today, she cut out and the starter won't budge. Today, when I get off the gas, the idle drops rapidly and sometimes the car stalls. Just happened, but this time no action when I turn the key. Waiting for cables and a multimeter. If the battery is good ill look at the wires to the starter. Anything else?
Old 07-25-2013, 06:02 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Dude - Hate to be a stinker but the data you have provided is lean.
Put yourself in the shoes of the reader and read your post again.
1981 911SC Targa
Old 07-25-2013, 06:15 PM
Senior Member
Jdub's Avatar
Sounds to me like an incomplete charging circuit that has drained your battery. Could be a dud alternator, or a bad ground or cable connection(s) to the battery.
When you turn the key (not start) do you see any lights in the gauges? With someone observing, what do they see when you turn the headlights on? Are they especially dim? Is the turn signal especially slow when you try that?
BTW, if the battery is over six years of age you might add that to your replacement list as a minimum. A bad cell or similar puts a lot of strain in the system and it is the cheapest spend in time and money.
'78 Targa in Minerva Blue
Old 07-25-2013, 06:23 PM
Lights are strong. Fuel whine in engine bay is strong. Ground strap, main harness, all wires in plain site are connected. I'll try the turn signal in a minute. Went to get a multimeter and a jack so I can check out the starter wires.
Old 07-25-2013, 06:35 PM
schumicat's Avatar
try push starting it.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 07-25-2013, 06:36 PM
Oh yeah, jump from another car had no effect. Too much traffic to push it....
Old 07-25-2013, 06:41 PM
sounds like the alt wasnt charging and killed the battery. if the alt light wasnt lit check the bulb in the guage and the connections on the back of it. its all related
Old 07-25-2013, 06:45 PM
emac's Avatar
Hate to be a ass but where are you. I'm sure there are many of us that can help
Ernie 81sc
Old 07-25-2013, 07:00 PM
Novato and grant in novato. Thanks.
Old 07-25-2013, 07:10 PM
Got it. Yellow wire slipped off starter. Jfc. Thanks all for your advice and concern. Great to have friends nearby in a crisis!
Old 07-25-2013, 07:24 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Thanks for coming back and following up with what actually caused the failure. Many people don't and no one can learn from the situation--so good job!
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 07-25-2013, 07:38 PM
