-   -   Steering not smooth (http://forums.pelicanparts.com/porsche-911-technical-forum/762767-steering-not-smooth.html)
Roby466 07-25-2013 08:46 AM
Steering not smooth
Hi guys,
I tried searching but no luck. My steering is kind of hard to turn. It feels like it is not smooth and I can hear it as I turn. It seems to come from box as I can feel the tie rods kind of vibrate when I turn (it is hard to describe). It seems like there is an excessive amount of friction in the rack. Is this something that is possible?
The car is a 1985 930 with almost 60k miles on the clock. I have ER front bushings.
Thanks for the help
Joe Bob 07-25-2013 09:07 AM
Does the wheel wobble up and down? Steering wheel bushing, easy fix.
szyzygy 07-25-2013 09:11 AM
I would recommend Mitch Leland's bushing as a replacement if that is indeed what your problem is. Search for his name on here and you will find additional info.
john walker's workshop 07-25-2013 11:43 AM
i just pulled a rack out today that was stiff with some extra freeplay and it was full of rusty water.
Roby466 07-25-2013 11:54 AM
That's what I am scared of... The steering column bushing is nice and tight, it kind of looks like the rack... Is there any way to lubricate it?
Ferrino 07-25-2013 01:04 PM
Yes, see here for an excellent guide, including replacement of bearings if you want to go the whole hog. This will require pulling the rack though.
Roby466 07-25-2013 01:20 PM
Thanks, I will have to it that on my list
Chuck.H 07-26-2013 04:05 AM
Before you take too much apart, try this simple test - disconnect the upper steering u-joint, the one just after the steering wheel shaft. Now spin the wheel and see if it's smooth. I was SURE I had a bad steering rack but my problem turned out to be a bad lower steering column bearing (bad like almost seized).
I found a way to R&R the steering column bearings without removing the column, using some bushings and pullers.
HTH,
Chuck.H
'89 TurboLookTarga, 360k miles
wswilburn 07-26-2013 04:30 PM
There are needle bearings at the top of the steering box and in the rubber sleeve in the linkage that wear out.
