Roby466's Avatar
Steering not smooth
Hi guys,
I tried searching but no luck. My steering is kind of hard to turn. It feels like it is not smooth and I can hear it as I turn. It seems to come from box as I can feel the tie rods kind of vibrate when I turn (it is hard to describe). It seems like there is an excessive amount of friction in the rack. Is this something that is possible?
The car is a 1985 930 with almost 60k miles on the clock. I have ER front bushings.
Thanks for the help
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 07-25-2013, 09:46 AM
RETIRED
Joe Bob's Avatar
Does the wheel wobble up and down? Steering wheel bushing, easy fix.
2012 ML350 3.0 Turbo Diesel
Old 07-25-2013, 10:07 AM
Pure Awesomeness
szyzygy's Avatar
I would recommend Mitch Leland's bushing as a replacement if that is indeed what your problem is. Search for his name on here and you will find additional info.
1977 Porsche 911
Old 07-25-2013, 10:11 AM
i just pulled a rack out today that was stiff with some extra freeplay and it was full of rusty water.
206 637 4071
Old 07-25-2013, 12:43 PM
Roby466's Avatar
That's what I am scared of... The steering column bushing is nice and tight, it kind of looks like the rack... Is there any way to lubricate it?
Old 07-25-2013, 12:54 PM
Ferrino's Avatar
Yes, see here for an excellent guide, including replacement of bearings if you want to go the whole hog. This will require pulling the rack though.
Old 07-25-2013, 02:04 PM
Roby466's Avatar
Thanks, I will have to it that on my list
Old 07-25-2013, 02:20 PM
Before you take too much apart, try this simple test - disconnect the upper steering u-joint, the one just after the steering wheel shaft. Now spin the wheel and see if it's smooth. I was SURE I had a bad steering rack but my problem turned out to be a bad lower steering column bearing (bad like almost seized).
I found a way to R&R the steering column bearings without removing the column, using some bushings and pullers.
HTH,
Chuck.H
'89 TurboLookTarga, 360k miles
Old 07-26-2013, 05:05 AM
There are needle bearings at the top of the steering box and in the rubber sleeve in the linkage that wear out.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 07-26-2013, 05:30 PM
