Obsessed
sobamaflyer's Avatar
Pic Request: Targa Bar Rosette
I promise I dug around for this....
I'm looking for a picture of a properly installed set or maybe an explanation as to just how they install. Or maybe these aren't supposed to go on my '75?
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 07-26-2013, 05:23 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I got this pic from the 7th page of posts in the below thread.
1976 Targa rebuild in Oz.
The thread may talk about how to install them but I used a heat gun on the plugs - they have teeth/ridges. Put a dowel in the plug hole and once softened, they go in pretty easy with a push. Get an extra one as things can "go wrong" the first time given experience level (ask me how I know)
1981 911SC Targa
Old 07-26-2013, 06:06 AM
Obsessed
so did your's look like what I have and I've got them on backwards (need to go on first before the rubber?
'73 Mercedes 450 SL
Old 07-26-2013, 06:20 AM
Obsessed
Thank you for that link, I'm starting to think I need to find what Dennis lists, plug/seals and maybe what I have is a later (964?) part.
'73 Mercedes 450 SL
Old 07-26-2013, 06:24 AM
Bob Kontak's Avatar
I am a little fuzzy in my memory regarding the faceplate. I am looking in the parts PDF's now to see if I can find an exploded pic. That should clear things up. I don't remember it in my 81.
Pelican Parts - Product Information: 999-703-186-40-M100
Pelican Parts - Product Information: 999-591-384-40-M100
1981 911SC Targa
Old 07-26-2013, 06:26 AM
Bob Kontak's Avatar
I do see plates like those that screw into the face of the front latch assy. You guide the locking handles into them.
1981 911SC Targa
Old 07-26-2013, 06:32 AM
Obsessed
thank you for the help Bob, placing an order for the right stuff.
I'll see if I can find a part no. on these to try and figure out just what they are as now I'm curious.
'73 Mercedes 450 SL
Old 07-26-2013, 06:37 AM
Bob Kontak's Avatar
See part 7. Not sure if the same as part in your pic.. See parts 53/54. Not seeing plate in rear.
1981 911SC Targa
Old 07-26-2013, 06:38 AM
Bob Kontak's Avatar
Originally Posted by sobamaflyer View Post
i'll see if i can find a part no. On these
901 565 299 45
1981 911SC Targa
Old 07-26-2013, 06:43 AM
Obsessed
part 7 sure does look like it, I'll have to look at my top later and see if they are already there and it's the same.
I believe you are spot on w/ the 53/54 parts.
'73 Mercedes 450 SL
Bob Kontak's Avatar
After seeing the price - get two extra pins.
1981 911SC Targa
Old 07-26-2013, 06:49 AM
theiceman's Avatar
yeah that plate doesnt go there in the first pic , they go at the front. the second pic is correct.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-26-2013, 08:50 AM
gtc gtc is offline
abides.
gtc's Avatar
The plastic part in your first photo attaches to your targa top where the handles fit into the latches. That is why it should say "auf" and "zu" (open and closed) on it.
Graham
1984 Carrera Targa
Old 07-26-2013, 09:24 AM
Those are tricky to get in you need to take an awl and weld a 12 mm washer on at 30 mm from the tip ,(the proper depth), otherwise you'll bugger them. They lock the rubber in then you put the cover pin in.
the plastic piece doesn't go there
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-26-2013, 12:29 PM
Bob Kontak's Avatar
How do you weld a washer onto plastic? Not arguing, as I remember, I jammed one of mine in too far.
1981 911SC Targa
Old 07-26-2013, 04:11 PM
Obsessed
I think he intends us to weld the washer on an awl, not the plug
Travis, sent from my Galaxy S3
'73 Mercedes 450 SL
Old 07-26-2013, 04:14 PM
Bob Kontak's Avatar
OK thanks - I remember now what I did. I rigged up a long-ish bolt - like a 10-32 - and did put a washer on it with a nut behind providing support. I can't remember what I used to push, but RSTarga is correct.
A dowel, or awl alone will push through the plug tip, especially if you warm it a bit.
1981 911SC Targa
Old 07-26-2013, 04:19 PM
Obsessed
That's funny, I read that earlier and thought "I don't have a welder but I bet I could rig up a bolt with a washer and nut 30mm down."
'73 Mercedes 450 SL
Old 07-26-2013, 04:55 PM
1: buy a cheap awl
2; buy a 12mm washer
3 slide the washer down the awl tip
4: weld at 30mm from the tip
An Ice pick will work too.
1991 C2 Turbo
Old 07-26-2013, 05:04 PM
Obsessed
I've been working on my vulcan mind control but it's not so far managed to fuse metal.
I considered metal putty that did a passable job fixing a hole in my muffler pipe
'73 Mercedes 450 SL
Old 07-26-2013, 05:26 PM
