at 25C (77F) latent heat of:
R134a 176 Water 2440 2440/176=13.86 Hence water has nearly 14 times more..... lol |
Good to know that wwest does not know how to read and comprehend. Lol
Here, we will show you the way Porsche 911/930 Air Conditioning Components We made pictures for you as hyperlinks at McDonalds for new employees. |
If a number appears anywhere on a page twice, it cancels. :) Now, seriously, the testing of the heat exchanger efficiency DOES NOT DEPEND on working fluid. If you use the same working fluid in each HE, then you will get very similar numbers, no matter what the working fluid. Of course, if you use a fluid with very little heat capacity, then residence time might make a difference. But that's a variable you want to eliminate. Ideally, you test the component using the working fluid for which it is designed. But test rigs are often not representative of real-world use. Test rigs are often meant as standardized methods by which everyone tests a particular material or component. No, it's not the real world. But folks are comparing apples to apples. What wwest is doing is multiplying one side of the equation by a number. But not the other side. On purpose. It's just a plain lie. And an easy one to spot. He gets an "F" for this math assignment. He got an "F" on the pressure rise calculation as well. He doesn't have very many more assignments be fore he flunks right out of this course... |
Please don't. It's bad enough that one person is lying with numbers. Don't give him even a little bit of credibility by doing the same in reverse. Dividing or multiplying the difference ratio between the two tests is bad logic and bad math. The latent heat for BOTH tests is the same with equal working fluid. And it doesn't matter WHICH working fluid one uses - the ratio will still be the same., and multiplying or dividing that ratio AGAIN by latent heat numbers is in essence multiplying or dividing one side of the equation by a number, but not the other. Epic math fail, wwest. |
To those without a math background, what he says might seem reasonable. But for those of us with both an analytical background, and strong math skills, his lies are blatantly obvious. |
Okay, in layman terms...
The molecular density of (liquid) water vs refrigerant GAS makes the water astoundingly more efficient for heat transfer vs refrigerant GAS. The more molecules, COLD molecules, flowing past, "touching" the inside of the condenser interior walls the better will be the heat transfer efficiency. |
Water was at 39F, airflow to be cooled was at 100F... OEM delta with water was, 100F - 62F = 38F, adjusted for R-134a, 38F/14 = 2.71F. "Other" delta with water was, 100F - 59F = 41F, adjusted for R-134a, 41F/14 = 2.92F. Kuehl delta with water was, 100F - 55F = 45F, adjusted for R-134a, 45F/14 = 3.21F. OEM R-134a delta = 2.71F Kuehl R-134a delta = 3.21F 3.21 - 2.71 = 0.50F In layman terms the Kuehl evaporator offers less than 1% difference in heat transfer efficiency. ... |
No. Lol.
The Kuehl unit was 6 to 7 degrees colder than OEM. And the Kuehl unit has fewer brazed/soldered joints compared to the OEM. Simply put, the Kuehl unit is the best 911/930 evaporator on the earth. |
Oh, and removing the "bowtie".. |
Sigh. Wwest. Please take your toys and go home.
A DIY can't easily repair corroded evaporator joints on a 25 year old fashion tube and fin evaporator. A DIY can't effectively repair an out of round commutator nor replace missing metal, nor worn bushings on a 25 year old motor And, post your data of gains you got observed by cleaning all of your neighbors 911 blower wheel vanes. And, post your graphical representation of the benefit achieved in cockpit air flow by simply removing the bow tie louver so the air hits the back of the console and the driver's leg. |
When I started planning the trip to Oregon on tertiary roads, wearing diapers, I kinda figured it was time for a little "space" from the Will-meister. I am far, far too unstable to be jacked with. http://forums.pelicanparts.com/uploa...1375300923.jpg |
Wwest. You are the one making up the funny math, theories about the benefits of cleaning 30 year old components with no proof... You have a new solution in search of a problem daily. how about this. post a video showing the increase in air in cleaning the evap, the drop in pressures to rebuilding old fans, The air temp drop in cabin with and without Bowie.... And then we will actually have something to refute.
Post the videos wwest!!! Quote:
w/bowtie: .................... Without: ................................. |
what do the dots represent? LOL
Post the video. Quote:
Food for thought. |
| All times are GMT -8. The time now is 05:37 PM. |
