jamesjedi's Avatar
77 911S Koni Strut - Big Washer?
Hi,
I am a looking for a little help. The top of me 911S Koni has a heavy duty washer (not the one that is shaped like a dish). I think it goes underneath the strut mount. Is this washer necessary? I dont see it in nay part diagrams.
Thanks for any help.
Old 08-22-2013, 09:47 AM
are you talking about the front suspension? if so you do not need it.
Old 08-22-2013, 09:51 AM
If it's around 5mm thick, it's a spacer that was used when Porsche ran a higher front ride height on US cars to meet period headlight height requirements. No, you don't need it, if you plan on running a normal 911 front ride height.
JR
Old 08-22-2013, 09:52 AM
jamesjedi's Avatar
Very helpful. Thanks, that is the part...5 mm, big washer.
Old 08-22-2013, 10:01 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Keep that big fat spacer for other future uses. Comes in very handy for pressing and clamping things. Recently used mine to "press" a steering column bearing in place by pulling the bearing in with some threaded rod. Big spacer was more than stout enough to pull against.
Kevin L
'86 Carrera "Larry"
Old 08-22-2013, 10:07 AM
jamesjedi's Avatar
I was going to keep...not sure why, but for the just in case.
Kevin, I will be get the hats and rotors soon. Will need to track down Clint. Thanks again for the help.
Old 08-22-2013, 02:05 PM
KTL KTL is offline
Schleprock
KTL's Avatar
No problem. If you can't reach Clint, nudge Max via the contact info address on Clint's site. That usually gets you a prompt response.
Kevin L
'86 Carrera "Larry"
Old 08-22-2013, 02:52 PM
