911 muffler.
Made an aluminum muffler for my 71 911 the other day on the cheap and thought I'd share a picture. First I made 2 flanges from an old exhaust gasket template and tapped them 1 1/2 NPT. Cut 4 pieces of 1 1/2 aluminum pipe and threaded the ends for the inlet pipes and outlets that come out the back. Used a 3" aluminum conduit with the bend already done . Photo has steel caps on but I have since turned up some aluminum ones. I stuffed it with insulation packing and then screwed on the caps. If you want to change the sound or packing you can unscrew a cap and pull it out the end. Sounds good and weighs next to nothing. I TIG welded the joints in a few spots just in case. Has plenty of clearance and costs very little.
Old 04-30-2013, 04:11 PM
Almost Banned Once
sc_rufctr's Avatar
Nice workmanship but being alloy how long would it last?
- Peter
Old 04-30-2013, 04:14 PM
Az911's Avatar
Send a message via AIM to Az911
Post a vid once you have it installed.
72T RS look
96 993
Old 04-30-2013, 04:19 PM
Not really sure. I made the flanges plenty thick and the conduit is heavy enough wall thickness that i dont think it will ever get hurt. I threaded and welded the joints because I wasnt sure what the heat expansion would do to them. I have been driving it for about a month now and nothing has cracked or come loose. Certainly not going to rust!
Old 04-30-2013, 04:20 PM
Guardsred911's Avatar
Right on.... That's tremendous..
J
911 SC - 1980
911 S - 1977
Old 05-01-2013, 04:38 AM
noavgdrvr's Avatar
sound clip please
Old 05-01-2013, 04:41 AM
schumicat's Avatar
isn't the packing restrictingh the flow? on most mufflers the exhaust is changing direction but it isn't blocked, or there are double walls and the packing is inside the outer wall.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-01-2013, 05:28 AM
tobluforu's Avatar
That's a trip and a half, looks like a pipe bomb, is it loud?
Old 05-01-2013, 05:35 AM
a.k.a. G-man
Geronimo '74's Avatar
More pics!
Look great, simple and lightweight!
I like!
Old 05-01-2013, 05:37 AM
H-viken's Avatar
+1
Very creative!
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 05-01-2013, 05:38 AM
IROC's Avatar
It would be funny if it showed something like a 20hp gain on a dyno.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-01-2013, 06:16 AM
Elombard's Avatar
LOL Mike ^
Yes I would Like to see pics installed and a sound clip if you can manage? Very cool.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 05-01-2013, 09:12 AM
Dublinoh's Avatar
+1 nice
Old 05-01-2013, 09:27 AM
Fb = M/S
aoncurly's Avatar
Won't you have dissimilar metals (aluminum and steel) in contact with each other at the flanges? I think this will accelerate the corrosion of the steel flanges and steel bolts.
Old 05-01-2013, 10:57 AM
Functionista
manbridge 74's Avatar
Motorcycles have had aluminum mufflers for years, so if you've got the correct alloy it might do alright long term. Use a copper flange gasket and no dissimilar metal issue.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-01-2013, 11:53 AM
ROW '78 911 Targa
timmy2's Avatar
Now that is what I would call a banana muffler...
Old 05-01-2013, 12:52 PM
Exotic Vehicles are here
1-ev.com's Avatar
nice
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 07-27-2013, 12:45 PM
Taking it apart is easy
Jerome74911S's Avatar
Have you tried other types of packing yet? Is the whole thing simply packed full? What type of packing, exactly, is in there now?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 07-27-2013, 01:03 PM
I have a white boiler type insulation in there that is wrapped inside of foil screen wire. Just got out of it actually. I will try to post a sound clip. It isnt packed clear full by any means and you can make it louder or quieter by changing how full you stuff it. Its a little racey but heh its a 911 not a Prius right?
Old 07-27-2013, 01:22 PM
It actually seems like it freed up the motor and makes more power as funny as it may seem. The car had two individual shorty mufflers on it and they were sooting up my bumper and I didnt like the sound anyway.
Old 07-27-2013, 01:27 PM
