Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
How to refill hydraulic jack ??
I have one of those small (2t) hyd jacks.
However, the lever moves but it doesnt rise.
I would like to try and add oil. How to do it ?
Old 07-31-2013, 05:23 AM
docrodg's Avatar
On my old jack there was a fill plug on the base next to where the pump handle was. open it up and fill, pump the jack a bit and fill again was procedure. My current jack has the fill on the cylinder and you raise it up, fill, then release.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 07-31-2013, 05:51 AM
emac's Avatar
Ditto
Ernie 81sc
Old 07-31-2013, 06:37 AM
Spiderman
Jesse16's Avatar
Good question, I have a pair of those cheap little bottle jacks and one seems to no longer go up. (they're only 25 years old and from China) The only place I see to add oil on my cheapies is the plug you open and close to control the raise/lower function. I'm gonna try adding a little bit there. Now can I use some kind of oil I already have without going out and buying a quart of "jack" oil. Not wanting another fluid on my shelf for 20 years. Probably cost more than getting another jack.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 07-31-2013, 08:01 AM
Spiderman
Jesse16's Avatar
ATF and Pwr. Steering fluid seem to be recommended substitutes. Also motorcycle fork oil, you get the drift. I've got a little GL-5 gear oil left so that's whats gonna go in mine.
Old 07-31-2013, 08:05 AM
midnight911's Avatar
if it lost fluid, it may also mean the jack is shot... adding fluid likely not work...or it may, ymmv. the cheap ones i ever had with similar condition never came back to life with adding fluid.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 07-31-2013, 08:44 AM
Hydraulic jacks........
Most of these hydraulic jacks/cylinders/bottles have fill -in hole with rubber plugs. I use hydraulic jack fluid from my local auto supply store that comes in small plastic bottles. The brand I have is 'SNAP' and comes in red plastic bottle.
Tony
Old 07-31-2013, 09:18 AM
Banned
Mine has that rubber plug so i'll try there.
I have another working one but it has a very small reach. It barely allows you to change a wheel on a 911. That's why i wanted to try the other one. I has hoping for more reach...
Old 07-31-2013, 10:16 AM
they tend to fill slowly, so i use a pump style oil squirt can.
206 637 4071
Old 07-31-2013, 11:16 AM
tharbert's Avatar
Unless it's leaked which should be obvious, I'd wager the seals are shot. I'd bet you could dismantle the whole thing and rebuild it but, at maybe $10 worth of o-rings and oil, it'd be more expensive than buyinng a new one.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 07-31-2013, 11:42 AM
