gptom's Avatar
scratches on chrome hub caps
What is the best way of removing scratches? I have used chrome polish- no help. I have a buffing wheel and that did not remove them. Do I need to have them re-chromed?
Tom
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 07-31-2013, 09:08 AM
You can try 4 '0000' steel wool on them, (really fine steel wool, not coarse).
It polishes up chrome really nice. I am not sure if it will remove scratches though, depends on the depth of the scratch.
Good luck!
Craig
77 Ice Green 911s w/3.0
Old 07-31-2013, 11:07 AM
Senior Member
Jdub's Avatar
There is no good way to pull a scratch from chrome by levelling it out to the adjacent areas using any sort of polisher or mild abrasive. What will happen is you will slowly see the chrome disappear, replaced by the brassy-colored layer underneath.
If the scratch is deep, rechrome. If it is light, you might have to live with it. Since there is typically a minimum charge for chroming, try to gather up enough parts to make the entire task/$ worthwhile.
'78 Targa in Minerva Blue
Old 07-31-2013, 11:21 AM
