Cheapest solution for brake light switch
I took my pedal cluster off the car to change the bushings for the bronze ones and got a big surprise because the old ones were perfect but anyway i changed them.
the PO had changed the brake light switch to the early mechanical one and i managed to re-brake the tab off while removing the pedals it looks like it had broken before but anyway i needed a way to fix it fast so i could use the car and since delivery from pelican takes a while to Mexico i decided to make a temporary fix using this lever momentary switch ![]() make a hole in the lever so you can insert a screw and use it to adjust when the switch opens and closes ![]() i made a mount with some aluminum angle stock i had ![]() this is the switch installed and adjusted ![]() it works perfectly and you can make fine adjustments in situ so the lights go on with minimal pedal travel but the best part was the amazing price, less than 1 dollar for the whole thing ![]() ![]() best regards
"It's only temporary unless it works" 1974 911s turbo-look stock 2.7 engine "Dirty Martini" 1953 replica 550 spyder built from the ground up, EJ25 engine Speeduino ECU |
Burnin' Rubber
Nice setup. I just finished using the Napa #SL128 supposed Cadillac Switch Mod. Worked out great and appears very similar to your setup (mine cost $20 though).
Cheers Last edited by Koizumi; 08-01-2013 at 06:39 PM.. |
A brake light switch is probably something you wouldn't want to jury-rig. If it goes out, you might have an SUV up your arse.
Steve B. 1972 911t 1999 328is |
Rescuer of old cars
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Burnin' Rubber
No worries here as I wired my switch to the brake pressure switch at the Master Cylinder. In essence, now I have 2 brake light switches, in case one fails, the other will activate!
I have long since replaced mine with mechanical switches, though on my '89 I put the switch on the brake booster bell crank in the front trunk. Chuck.H '89 TurboLookTarga, 361k miles |
I see two wood screws in this setup. The premise is good but the execution is a little weak. But hey, what could go wrong?
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Actually its the same solution porsche had with the mechanical switches but while waiting 3 weeks for it i can use this as a temporary fix, the only wood screw is the adjuster but ive already changed it for a normal one with a lock nut, all the other screws are stove type with nylocks and since ive read a lot in the forum that pressure switches tend to fail a lot i think i have the same chance of failure
Regards |
