How to fit a 915 rubber boot into G50 center console
Hello,
Here's how to fit a 915 rubber boot into a G50 center console. G50 center console hole diameter is bigger than that of 915 boot thus boot will become loose & come out of the hole when you shift thus making it unsightly. The solution is to add a layer of leather / vinyl / foam to hold the rubber boot base from coming off of the hole of center console. Stuffs needed: 1. Sheet of leather / vinyl / foam ( I use foam) 2. Glue. 3. Scissor. Steps: 1. Cut a hole on the foam the size of boot diameter. 2. Glue the edge of the foam onto the console from the inside. 3. Slide the boot through the foam. http://i269.photobucket.com/albums/j...ps3249d27f.jpg http://i269.photobucket.com/albums/j...psd6db35b9.jpg http://i269.photobucket.com/albums/j...pscd1ea514.jpg http://i269.photobucket.com/albums/j...ps483004e9.jpg http://i269.photobucket.com/albums/j...ps426e88c0.jpg Before http://i269.photobucket.com/albums/j...1/100_2136.jpg After (pardon my hairy leg) http://i269.photobucket.com/albums/j...psbf1eb78e.jpg |
Interesting. How do you like it?
BTW, please delete the double post. |
| All times are GMT -8. The time now is 01:34 PM. |
