I have a "PERSONAL" steering wheel with the correct hub on my 1987 Carrera.
I messed up in trying to adjust the position of the wheel by trying to remove the 6 screws that attach the steering wheel to its hub. 3 of the screws can no longer be removed because the grip for the allen key got enlarged and it is round now. Any suggestions as to how can I remove these screws??? |
Pro Grabit® 3 Piece Kit
Next time use allen keys that have rounded ball ends on them so that you can attack at an angle without rounding them out.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
Northern Motorhead
You might want to try a metric or sae size allen socket that would be a little bigger than the original size and tap it on with a hammer,sometimes it will just fit tight enough and allow you to remove the stripped allen screw !
Cheers Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Mike '89 CARRERA #402 |
Steering wheel
Thanks guys....your suggestions did not work BUT I ended up drilling the screw top and hammered gently an extractor I had that got a good grip ...and then with using my drill, I gently turn the extractor counter clockwise and all 3 screws came out.
I bought new screws and reassembled the wheel and positioned the turning signal cancel tab at 9.00 and everything works perfectly. |
