Brake Caliper Rebuild / grease removal?
I'm in the process of rebuilding my rear calipers and I've had to remove the pistons using a grease gun (worked great, btw). How do I now remove the grease that has filled the inside of the caliper?
'70 911S 1002938 '70 Ducati Mark 3D 350 |
76 911S Targa
Use a suitable solvent for grease. Gasoline works. Diesel works. Paint thinner works. Those are probably the cheapest options. Work outside with the wind at your back. Spray cans of starter fluid are useful for minor cleanup.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Senior Advisor
got to get medieval dirty, use your fingers, scrape the goop out, dunk in solvent, use a brush, air dry final cleaning with fresh brake fluid. Rebuild as normal
08 Cayenne Turbo |
Do I need to split the caliper?
AutoBahned
no
do buy some of Porsche's magic brake paste and use it |
Thanks fellas... solvent and a warm ultrasonic bath, followed by lots of compressed air worked perfectly.
R. - I will look into this magic brake paste - thank you.
'70 911S 1002938 '70 Ducati Mark 3D 350 Last edited by derek murray; 08-05-2013 at 08:45 AM.. |
I had to do this recently on one stuck piston. I used brake cleaner and compressed air to get the grease out of the narrow passages. Just when I thought I was done more grease would come out. Keep going at it and then go at it some more...
Thanks, -Roger '87 924S |
