911 no start
Ok, so I finally got my 81 911 SC into the 78 911 Carrera body. but it wont start. Like nothing, no starter nothing. It 'ran' in the 81 just fine, so what could I be missing on the 78? the speedo hasn't been installed yet but I don't think thats it... Any Ideas?
Old 12-24-2013, 03:29 PM
pors1968's Avatar
First guess yellow wire on the stater on wrong spade
Old 12-24-2013, 03:44 PM
ok haha give me 5 min.
Old 12-24-2013, 03:48 PM
So I should probably add, when I connect the battery the car powers on, like the key is in the ignition. but the key is still on the seat. Nothing happens when I put the key in and turn it.
Old 12-24-2013, 04:14 PM
Starting problem.......
If the starter is not turning, check these:
1. Cable ground strap at transmission to chassis.
2. Battery is fully charged.
3. Starter is in good operating condition.
4. Check power at the yellow wire terminal (starter solenoid) when you crank the starter.
You have to make the starter crank or turn to get the engine running. So this is your main goal. Power to the yellow terminal (solenoid) to activate the solenoid/starter. Keep us posted.
Tony
Old 12-24-2013, 04:51 PM
I'm almost positive its the ignition switch, sounds a lot like:
83 SC - Iginition Switch Issue
Old 12-24-2013, 05:50 PM
pors1968's Avatar
If you had any problem before changing engine and you have power whithout ingnition i would look at the alternator connection red wire.
Old 12-26-2013, 04:30 AM
