Removing that darn lock knob guard-thing
The guard for my lock knob had a piece snap off, so I ordered a new guard from our host. However I can't get the darn old one off! Is there a trick to releasing the glue without tearing the vinyl? Or should I just go after it with an exacto knife?
http://forums.pelicanparts.com/uploa...1375753403.jpg |
the one I have seen are no glued .
just remove the center screw and the knob and cover fall off. |
Remove the screw and knob and the cover should fall off. |
+2, you may need to use a pin tool or simply twist off the out cover and it will take it with it. Lefty loosy.
Damn it broke :( |
The surround actually has threads on its inner opening and screws down onto the inner door panel it helps hold the door card against the inside of the door. Remove the screw, pull straight out on the knob, then like Draco said, "lefty loosy". -J
| All times are GMT -8. The time now is 04:58 PM. |
