Removing that darn lock knob guard-thing
The guard for my lock knob had a piece snap off, so I ordered a new guard from our host. However I can't get the darn old one off! Is there a trick to releasing the glue without tearing the vinyl? Or should I just go after it with an exacto knife?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
the one I have seen are no glued .
just remove the center screw and the knob and cover fall off.
Billy, MoosgrunMetallic - 81 911 SC - (Carbon fiber Wrap) Drank the Koolaid in 82 |
Remove the screw and knob and the cover should fall off.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Member 911 Anonymous
+2, you may need to use a pin tool or simply twist off the out cover and it will take it with it. Lefty loosy.
Damn it broke
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 08-05-2013 at 09:30 PM.. |
Go-Kart Mozart
The surround actually has threads on its inner opening and screws down onto the inner door panel it helps hold the door card against the inside of the door. Remove the screw, pull straight out on the knob, then like Draco said, "lefty loosy". -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken Last edited by JAR0023; 08-05-2013 at 09:51 PM.. |
